ir 3245 E000315-0520
  • mido
    • Nov 2011
    • 177
    Dear all
    Merry Christmas to all
    I have a problem in IR 3245, it display e315-520 after copying black copy with lines
    pls can anybody tell me about this error code
    thnx
    Re: ir 3245 E000315-0520
    Does it still error when you do a report print.
    315-0520 Device: timeout error
    [Location to be detected] image process module (CMIP)
    [Detection timing] When there isno interruption 2 min after the
    operation has been started
    Check connection with DDI-S cable(RCON). Replace the main
    controller PCB.
    • mosey1100
      • Mar 2009
      • 143
      Problem :
      Error codes E315-0500, E315-0510 and E315-0520 occur when sending a fax. When faxing from the platen glass the fax job would complete with no error. The error codes would happen only when faxing from the DADF.
      The MMI, MNCON, and DCCON clears were performed. Also, the Main Controller PCB was replaced with no change in the symptom.
      Solution :
      In this case, an RCON clear was performed. After performing the RCON clear, the door values were re-entered thus resolving the problem.
      • mido
        • Nov 2011
        • 177
        Originally posted by mosey1100
        Problem :
        Solution :
        Hi,
        Merry Christmas
        I re-entered the door values, it works normally about 30 copies then it displays E000315-0510,
        Is there any problem in dc con?
        what can I do??
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5013
          Try with new DIMM.
          • stevelightyear2000
            • Jan 2012
            • 9
            Originally posted by zoraldinho
            Try with new DIMM.
            i have had problem with the cable that goes from reader controller to main controller
            • syed009
              • Aug 2013
              • 3
              black lines ok and black copy
              first in drum earthplate gold color plate is there press small down
              drum unit no
              drum gear side opposite one hole earthplate gold color plate is there press small down
