ir3570 ethernet connectivity
  • teckat
    • 16083
    #31
    Re: ir3570 ethernet connectivity
    Originally posted by DAG COPIERS & COMPUTERS
    Hmmmm! So what is blocking our data transfer? Ping only verifies configuration and tests the connections if they are proper or not, but doesn't guarantee network com. If I may ask, Are you running a 32-bit or 64-bit version of windows7 on your computer? Generally, Device drivers designed for the 32-bit version of windows don't work (correctly) on computers running a 64-bit versions of windows. So make sure you download and install the iR3570 driver appropriate(matching) with the windows OS version running on your computer.
    - You also talked of your BOOTROM version as 3.03, without the 'N' or 'C' being specified. To eliminate any doubt I would try to replace this with a known working 'N' version.
    - Ensure proper contacts at the connection terminals. Try another crossover cable. These could be simple or minor steps, but often overlooked by most techs who often charge into the equipment to look for a non existent fault.
    that posted Boot Rom information ???
    looks like ver. was taken off boot rom // it means nothing
    need to see correct ver. info on a print out or viewing in service mode DISPLAY>VERSION
    FM2-3117 01
    J1010 - Type A
    version 03.3
