imagerunner 2318 stackbypass issue
  • montana
    • Aug 2008
    • 392
    hi everybody..i have an issue with canon imagerunner 2318 stack bypass the inner tray does not lift up to to feed the paper and make alittle noise it sounds like the gears are not engaged to move properly..any solution gentlemen???thanks
  • edward robby
    Re: imagerunner 2318 stackbypass issue
    i think thers a solenoid that not functioning , or needs a modification.
    • montana
      • Aug 2008
      • 392
      hi..thank you edward...i think the solenoid is working ..but how to modify it?
      thanks again
      • canonbundy
        • Jun 2012
        • 607
        Did this problem start after replacing the Fixing Film Assy? If so, check the connector INSIDE the door, a common thing that happens when removing the L/H door is the connector with the Purple wires has not been disconnected from the Frame and the force of removing the door may partially disconnect the connector inside the door, which may also cause the machine to display 1 to 2 Sided copying ONLY.
        • arielcanon
          • Mar 2012
          • 106
          increase spring tension of SPRING TORSION no 37.., to increase force, so that the gear will be engaged correctly.
          Learning never ends..
          Never give up, where there is a wheel there is a way..
          • edward robby
            [just remove the foam and replace with any hard sticker, with atleast 2mm. of clearance when you close the metal plate. sometimes thats the real caause, yes. the solenoid is working but i think its intermitent. the activation is not constant.. like timing error , because of sticky old foam. :-D
