What's the oem code for imagePRESS C1 lower sleeved roller?
  • juancpgo
    • Aug 2025
    Hi, I need urgently the oem code for imagepress C1 lower sleeved roller / pressure roller.
    I have searched all over the internet and I can't find it.
    Does this part have some other name for this machine?
    Thank you very much
    Re: What's the oem code for imagePRESS C1 lower sleeved roller?
    FL2 6945 000 I believe (not worked on this model)imagepress-fuser-pc.pdf
    • juancpgo
      Originally posted by skynet
      FL2 6945 000 I believe (not worked on this model)[ATTACH]18784[/ATTACH]
      That's Upper Fuser Roller, and not Lower Sleeved Roller, as you can see in the link below:
      Canon FL2-6945-000 Upper Fuser Roller, Genuine (M1234)
      • juancpgo
        That's the code for "Upper Fuser Roller", and not "Lower Sleeved Roller".
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5018
          This copier have upper fixing roller and fixing film.
          • teckat
            • 16083
            Before installing a belt, apply silicon oil to the marked area of the pressure pad cover (within the radius of about 200 mm from the center).
            Apply silicon oil to the pressure pad cover, after soaking lint-free paper into the oil to the extent that
            the oil does not drip from the paper.
            • Phil the copy guy
              • Sep 2009
              • 36
              Thank you very much
              I off today but have info feel free to call me at home 413-429-6467 phil
              • Phil the copy guy
                • Sep 2009
                • 36
                [QUOTE=Phil the copy guy;331904]I off today but have info feel free to call me at home 413-429-6467 phil[/QUOT
                Sorry my email is pfabres@aol.com
                • juancpgo
                  [ATTACH=CONFIG]18787[/ATTACH]
                  Thank you for your help man!
                  That's what I needed.
                  • zoraldinho
                    • Mar 2008
                    • 5018
                    Any time.
