Canon IR105 E004 0001
  • otomatic
    • Jun 2009
    • 26
    hello all
    our ir105 has started the day throwing codes
    the first one was 010 and did the troubleshooting in the manual only to have it now do a e000 then cleared it and now it's doing e004-0001
    the manual has no indication of what the 0001 part is and suggests replacing the AC driver board and if that didn't work replace the DC controller
    is there anything else I could check to find the actual problem before we take that expensive fishing trip
    thanks
    Mike
    • 16083
    Re: Canon IR105 E004 0001
    Originally posted by otomatic
    hello all
    thanks
    Mike
    E004-0001
    It may be necessary to replace the AC Driver PCB.
    The SSR is incorporated into the AC Driver (Part Number FG6-7264-000).
    did u check the heater lamp for damage
    • otomatic
      • Jun 2009
      • 26
      Originally posted by teckat
      E004-0001
      is the SSR the relay on that board? if so iv'e checked those out and they seem to be working
      they both (AC board, DC board) click on then off at start up then the code after that
      I didn't check the lamps yet....
      • otomatic
        • Jun 2009
        • 26
        I've checked the lamps and they are ok
        checked wiring from the AC board to the lamps and ok
        but the ground was open...traced it to the thermal protector and it was open
        new one on the way
        thanks
