I've attached test sheets for a problem I am having, voided areas on black only, colors are fine. I think I have eliminated the drum and transfer belt since we have swapped the entire process unit out with another working copier and the problem still exists. Any ideas are appreciated.....I am new to this particular model.
irc2880 white lines
Tags: None
Re: irc2880 white lines
If a white line is found in a specific color, suspect a fault in the development system, transfer system or drum of that particular color.
Check Black Laser --
U SWAPPED THE ENTIRE PROCESS UNIT-
did u perform this first
Service Mode COPIER>FUNCTION>INSTALL >AINR-OFF invalidates drum initialization that is performed when a new drum unit is installed. Also, the fuse is not blown, as it would usually be after drum initialization is complete.
This mode would be used to replace a drum unit temporarily in order to check image quality, for example trying to trace the cause of the problem.
0: Initialization carried out for new unit. Fuse blown (Default)
1.: No initialization for new unit. Fuse not blown.
Further, this service mode should be set to [1] only when necessary for service. After the service is complete the setting must always be returned to [0].**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Clean your laser with the tool that is inside the front door.
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
Ditto that. Clean the laser slit glasses, especially black. =^..^=If you'd like a serious answer to your request:
Yep, cleaned slit glass and that was the problem, I feel like an idiot. Thanks guys!Comment
