Canon Ir-5000 E-0001/6000 warming up
  • jose antonio
    • Dec 2012
    • 119
    [Error Code] Canon Ir-5000 E-0001/6000 warming up
    Hi, I have two machines at the same customer giving these strange problems.
    One is a Ir-5000 with intermittent E-0001 errors: so far i replaced the thermistors, checked the connectors on fixing unit and DC controller .
    After reset errors , the machine runs for a couple of days than same problem again, even swapped the complete fixing unit, but problem comes back again.
    The other machine an Ir-6000, also intermittent: warming up for ever but heaters don,t come on. After ram clearing, machine works again for some days, than problems come back. These problems make me suspect input power related, but every time I,m there power input is normal.
    Any ideas would be appreciated.
  • Brian8506
    • 1664
    Re: Canon Ir-5000 E-0001/6000 warming up
    On the 6000 check male and female connectors on fuser and machine frame for any paper. I've had to replace these connectors for those codes but it's not a fun job.
    • Chameleon
      • Nov 2011
      • 200
      I have seen that problem on a few ir5000's and like Brian said check the connector on the back of the drawer and the one on the rear frame get chuncks of paper or broken. The screws for the left side drawer rail come loose and can mess with the alignment of that connector.
      A FEW OTHER THINGS TO CHECK. You didn't mention replacing the lamps, but I had one recurring E001 that was fixed from replacing the lamps. Also, there is a connector PCB below the LFR heat shield that gets extremely dried out and brittle and needs replaced.
      The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
      • jose antonio
        • Dec 2012
        • 119
        Checked those also on the fixing and machine frame but not on back of machine.
        • jose antonio
          • Dec 2012
          • 119
          No I did not replace the lamps.
          I will go back today and check those lamps and connector PCB.
          Thanks for the info!
          • Northwestservice
            • Jan 2011
            • 140
            lets see, along time ago there was a mod that refered to this problem, and the fix was to use a couple of small washers to shim the fixing contacts on the rear of the machine in so there would be a more positive contact to the fuser ..we are only talking 1/2 - 1 mm thick washers
            • jose antonio
              • Dec 2012
              • 119
              Looks like I found the problem, the past days the machine began giving E 0004-0000 codes also.
              Than I decided to replace the AC driver PWB, located on the back to the right side on the machine.
              No more problems since than.
              • jose antonio
                • Dec 2012
                • 119
                • Simons
                  • Jun 2008
                  • 490
                  Other than that when several occur it can because of poor wall socket power or not on a 20 amp line.
                  • teckat
                    • 16083
                    I would have also replaced Relay= RL1/located under the right, lower corner of the MN-CON PCB.
                    • jose antonio
                      • Dec 2012
                      • 119
                      I will observe the machine for the next days first see how it does,customer needs some pending nbprinting jobs to finish first since the machine has been up and down for most of the time these last days.
                      Thanks.
                      • canonbundy
                        • Jun 2012
                        • 607
                        As well as checking for bits of paper etc in the connectors as previously suggested, clean the Contacts at the Rear of the Machine and also the Drawer including Duplex Unit with WD40 or RP7 and a clean lint free cloth. On all these Gagets where the Fuser Drawer is constantly pulled out (especially when they have age), the Contacts tarnish and sometimes do not have a good connection often creating different Error Codes but relating to a similar fault.
                          • 22999
                          I've had pretty good success with Electrokleen for cleaning those connectors, but sometimes there isn't an obvious fault. Fuser oil coats the contacts and provides resistance in the connection. Shimming the connector only helps if it's not coated with fuser oil. If you shim the connector too close one of the connectors will shatter. Yes I've done it myself.
                          You may need to replace the connectors to resolve this problem. =^..^=
                          • jose antonio
                            • Dec 2012
                            • 119
                            I did the cleaning and shimming on the contacts , but the problem stayed so I decided to start replacing
                            Components starting with the thermistors , than the DC Controller but problem came back just after a few prints.
                            The codes din't come back after replacing the AC Driver PCB though.
                              • 22999
                              ... The codes din't come back after replacing the AC Driver PCB though.
                              Ah! It sounds like your done fixing then. =^..^=
