Error codes 00025-0004
  • Suvenirufabrika.lv
    #16
    imagepress c1 error code e000747-051c
    Help! imagepress c1 error code e000747-051c
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      #17
      Re: imagepress c1 error code e000747-051c
      First pull out all sub pcb from main controller and clean contacts.
      Next time suggest new thread.
      • teckat
        • 16083
        #18
        Measures for Error Codes Caused by Poor Contact between Sub PCBs and Main Controller PCB
        When poor contact develops between one of the Sub PCBs [1] and the Main Controller PCB [2] , various
        kinds of error codes or malfunction to the machine may occur.
        When one of the possible error codes is displayed, perform the procedure outlined below.
        Required Tools:
        • Philips Screwdriver (standard size).
        • Ruler
        • Alcohol
        • Lint-free Paper
          #19
          Re: Error codes 00025-0004
          canon imagepress c1 error code e000061-0001
          • teckat
            • 16083
            #20
            Check to make sure there is no foreign matter on the Primary Corona Assembly.
            In one case, a piece of the old corona wire was stuck in the unit causing arcing. Also make sure that the wire is properly sitting on the little wire blocks on each end of the unit.
            A missing drum shaft knob screw can cause the E061 0001.
