Change scanner mode to Online on canon ir2018 with no touch pad screen.
  • roines
    • Jun 2025
    Please I am using a canon multi-function printer with printer, scanner and fax capabilities. I installed the URFII driver and the Network ScanGear software and everything worked well until when I tried to scan and was asked to change the scanner mode to "Online". All the documentation I have shows how to do that using the touch pad panel. My canon machine has a small LCD screen that shows in text mode only. I don't know how to go about to change the mode of the scanner to Online.
    Can anyone help me with the procedure to follow to change the scanner to online mode on ir2018 which does not have a touch pad control panel but a small text mode LCD screen?
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Change scanner mode to Online on canon ir2018 with no touch pad screen.
    Hello,
    There is a dedicated scan button as indicated in the attachment.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • Rachid.Akli
      • Oct 2011
      • 595
      Originally posted by Rachid.Akli
      Hello,
      Rachid.
      Sorry, the scan button is hidden in the PDF.
      Rachid.
        • 16083
        is this your control panel ????????????????????
        Press (Additional Functions)
        • roines
          [ATTACH=CONFIG]19033[/ATTACH][ATTACH=CONFIG]19034[/ATTACH]
          s
          Thank you very much tectat for the response but I can't seem to find the [Auto Online/Offline] option in the [System Settings]. For information, the [System Settings] has only 8 options in my machine.
            • 16083
            s
            what are options ???????????????????
            look under System Settings
            >look under Communications Settings
            NOTE-
            I believe Send Function, is available only for the “i” models
            Send is not available for
            2018/2022
            also Optional for:
            2018/2022 = PCL Printer Kit-V1
            also Optional: Super G3 Fax Board-AA1 (Single Line)
            • Rachid.Akli
              • Oct 2011
              • 595
              I'll try to resume what i understood from your thread:
              1- You have an iR2018 with a small screen display.
              2- You want to use color scangear.
              3- You don't know how to put the scanner online.
              In my above reply, i sent you an attachment showing the scan button. Have you read it ? Does this button exist on your controlle panel or not ?
              Rachid.
              • roines
                NOTE-
                I believe
                2018/2022
                also Optional for:
                The options are:
                1. SYS. MANAGER INFO
                2. DEVICE INFO
                3. MANAGER DEPT. ID
                4. MANAGER USER ID
                5. NETWORK SETTINGS
                6. REMOTE UI
                7. CHECKING THE LOG
                8. LIC REGISTRATION
                9. USE DEVICE USB
                Sorry I said 8. There are just these 9 options under SYSTEM SETTINGS.
                COMMUNICATIONS SETTINGS DOES NOT EXIST NEITHER.
                  • 16083
                  The options are:
                  2. DEVICE INFO
                  3. MANAGER DEPT. ID
                  4. MANAGER USER ID
                  5. NETWORK SETTINGS
                  6. REMOTE UI
                  7. CHECKING THE LOG
                  8. LIC REGISTRATION
                  9. USE DEVICE USB
                  Are u under a Dept ID Management w/ Password ??
                  or using System Manager ID
                  What happens when u press the Scan) on the Basic Features screen.
                  is this what u see when u press ADDITIONAL FUNCTION KEY ON CONTROL PANEL ??
                  when u hit SYSTEM SETTINGS do u see below
                  • roines
                    [ATTACH=CONFIG]19053[/ATTACH]
                    [ATTACH=CONFIG]19054[/ATTACH]
                    I don't have a wide screen as the one show. The following picture is an exact copy of the control panel I have in front of me.
                      • 16083
                      [ATTACH=CONFIG]19055[/ATTACH]
                      OK !!
                      That looks like a Two Line window iR2022/2018 230V EUR Panel
                      /w left side cover
                      did u download/set up the Network Color Scan Gear ???????????????
                      Its available in the Printer driver CD or you can download it from Canon's site.
                      http://www.usa.canon.com/cusa/suppor...ersAndSoftware
                      File Name: ColorNWSGv271.exe
                      Color Network ScanGear v2.71 for Windows XP/Server 2003/Vista/Server 2008/7
                      Network ScanGear User.pdf
