Canon 2050 fax
  • copyman
    Owner / Technician
    • Sep 2005
    • 4708
    Canon 2050 fax
    Intermittent alarm light. Machine will still operate but wondering what it means. It will go away for a few days then come back. It has new toner, paper, etc.
    When light comes on customer has removed and installed, toner, paper, powered on and off and light stays on. Then one day it will be suddenly be off. Strange thing is machine still seems to operate normally when light is on.
    Any ideas appreciated.
    Thank You
  • Chris Good
    • Jan 2013
    • 5
    Re: Canon 2050 fax
    Thank You
    Could be a recycled toner cartridge causing this. Also check the toner cartridge sensor assembly which is mounted on the same frame as the laser scanner under the top cover. It could be out of place.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: Canon 2050 fax
      Clear all sometimes help.
      • kiwitech
        • Oct 2012
        • 29
        Re: Canon 2050 fax
        i'm not familiar with model but sometimes alarm will flash when memory is full. check to see whats still in memory ( memory reference). there is probably a user mode setting to delete or erase failed fax transmissions. this will stop the memory filling up
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Re: Canon 2050 fax
          Sometimes its the simplest things.
