well i have a irc4080 copier, i start to have color displacement so to fix it, i did this.
1. first clear the ITB (gears, rollers, inside the ITB) then the gears inside the copier.
2. make a auto graduation,(FULL)mm and print the PG6 and PG10
after this i saw i have a displasment in the vertical guides but the horizontal where ok.
3. then I check out the drums and their were ok, even open the drums to check out.
4. i made a DC-CON clear,, after this unplug, for 5 seconds,
5 after this made a auto grad 3 times, and a PG6 and PG10
now the horizontal are wrong but the vertical are ok..
so what can I do rigth now.?
here its the attachment.
thanks for your help. PG6and10.pdf
