canon IRC4080 color displacement (another post)
  • teckat
    • 16083
    #16
    Re: canon IRC4080 color displacement (another post)
    Originally posted by V-P
    I have a case with this modification. I have put the varistor inside the metal part.
    Accidentally saw (from the rear side) that the film was discharging to my finger while machine was printing.
    So I put a little cable which is touching film on one side and the metal shaft on the other side.
    How come this electrical discharge ?
    never seen that issue/
    just make sure u use a metal screw on one end/ do not use a plastic screw> needs to be grounded
    or it will throw >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    E003 0001, E004 0101/ 0401, or E007 0201 errors/or
    Jam Code FF90 ----------------
    varistor
    helps to dissipate charges built up in the ITB assembly.
    • V-P
      • Apr 2011
      • 679
      #17
      I did put a metal screw. It has fixed the problem. No errors whatsoever.
      I was after a magenta leak on the entire page when I saw the discharge in my finger.
      I don't know why on some drums (magenta only) - developer looses its magnetic power and starts to overflow.
      • Simons
        • Jun 2008
        • 490
        #18
        overtoning on magenta is most likely due to heavy usage and then things get thrown out of whack. Ive seen this on some HP printers too.
        • teckat
          • 16083
          #19
          One point to note:
          for 5180 series only
          did u ever see that old 2009 ITB update for plate on 5180 series / they had a retro fit to change the gap
          to prevent blurred or smeared images ??? useful only as a temp fix on older ITB Units- and ones that have never been replaced from 2009----------------------------
          ITB_TP08 285b.pdf
          the newer (FM2-5365-010) ITB Units in 2009 was supposed to fix this issue/ but it doesn't/never has paned out for customers who use this printer as a printing press
          like I said before/ it's all about paper type + % coverage= eventually blurred or smeared images/
          the varistor & plate removal has prevented about 60/70% recalls on CQ Plate issues /
          u ust need to tell customer to be careful reaching in to remove jam paper underneath ITB
          • V-P
            • Apr 2011
            • 679
            #20
            Yeah I had that retro fit done in 2 units. A lot of little jingles - not a life changer though.
            I will try to shoot a video of the electrical discharge on my finger just for fun.
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5015
              #21
              • V-P
                • Apr 2011
                • 679
                #22
                lol - It is very similar to that
                • teckat
                  • 16083
                  #23
                  check printer ground at outlet
                  GROUND TO NEUTRAL= 0v/0.5v Max
                  • V-P
                    • Apr 2011
                    • 679
                    #24
                    I suspected that too. Very old building. Crappy electrical wiring. Best combination.
