waste toner container is full
  • satish.ambiger
    • Aug 2012
    • 24
    Hello
    I have 5570 i cleaned the waste toner container but again and again it is showing waste container full please help me to solve this problem
  • Hitesh_honey
    • Aug 2011
    • 19
    Re: waste toner container is full
    Originally posted by satish.ambiger
    Hello
    my dear pl clean waste toner pipe line. in this pipe one spring joined to carry toner out side in waste toner container. pl clean this is also. on the top of this pipe one couple gear attached it's jam. release spring that couple gear automatic release and waste toner indicator switch also resat.
    • jose antonio
      • Dec 2012
      • 119
      Hello
      Did you clear the counter in service mode?
      Check in service mode Copier>Counter>Misc>WST-TNR, clear to zero.
      • Fer
        • Nov 2009
        • 267
        Waste toner must be cleared in service mode for this model. A clogged tonerpipe would give E0013 error.
        • gensys
          • Jan 2011
          • 323
          Hello
          Before to ask a question, use search...
          http://www.copytechnet.com/forums/ca...container.html
          The Road will be Mastered by >>> the Going...
