Canon IR 550
  • pontiac
    • 420
    Canon IR 550
    Good day everyone. I am new to the canon line so i have a lot to learn. I have ir 550 that is giving me a E-066 code, i have replaced both transfer and charge assemblys and still no resolve what elase should i check or can i turn the cleaning cycle off so that autoclean will not activate. This copier is used for short term rentals as in 2 to 5 days so i can clean the coronas when needed. If there is something i am missing please let know , I do appreciate the help. thanks to all.
  • kwazimoto
    • Jan 2007
    • 199
    the problem is with the pre transfer asm... the cleaner home pos..
      • 23007
      Look for a shorted or pinched wire on the backside of connector J12D under the operation panel. Cut the two nearest tie wraps to connector J12D (or possibly J124D).
