Canon IRC 2620 Color Alingment out
  • fbkhan3
    • May 2012
    • 421
    [CQ] Canon IRC 2620 Color Alingment out
    Hi folks
    Hope you doing great in machines land,i have color alignment issue with given above model.. at first it was complete mess, after cleaning the rubber Rollers inside the ITB,Transfer Roller,Laser Housing and Auto Gradation Adjustment(Full) with Plain paper
    now yellow,Megenta and Cyan seems ok it's only issue remains with Black color,Machine has 123398 clicks on it.
    B&W copies are ok,i'll upload the sample tomorrow if get one.
    I'm out of ideas here,hope someone here can help me out with this.
    Thanks in advance .
  • Fer
    • Nov 2009
    • 267
    Re: Canon IRC 2620 Color Alingment out
    Dirt on the inside of the belt transfer back to your just cleaned rubber rollers. Beter is to clean the inside of the belt with alcohol of replace it.
    • teckat
      • 16083
      Originally posted by fbkhan3
      Hi folks
      Thanks in advance .
      Also make sure your interior primary rollers are sitting correct/ check both ends of the spring plastic holders for crack
      post PG10 & PG6
      READ--
      • fbkhan3
        • May 2012
        • 421
        Thanks a million Tacket,i'll go through the steps mentioned in the guide and let you know,
        you really run the show man,Thumbs up!
