USB port in IR 3235n
  • mido
    • Nov 2011
    • 177
    Hi all.
    I want to know, what is the function of the usb port located in the left side of the control panel in IR 3235N?
    Can I use this port to read files in the flash memory?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: USB port in IR 3235n
    No
    • mido
      • Nov 2011
      • 177
      Originally posted by zoraldinho
      No
      sorry sir, what do mean by no?
      can you tell me what is its fucntcion?
      • Cabo
        • Aug 2012
        • 41
        Use for upgrade firmware with USB Memory stick
        • cableties
          • 35
          prints pdf
          • Cabo
            • Aug 2012
            • 41
            For print PDF you must buy licence
            • zoraldinho
              • Mar 2008
              • 5016
              Need USB Memory Connectivity Kit-A1
              Enables support of USB removable media devices into the USB port on the control panel to print data stored in media, save scanned data or data stored in Mail Box to media, etc. PDF, JPEG, and TIFF file formats are supported.
              • mido
                • Nov 2011
                • 177
                Thank you for your replies.
                How can I know if the licenes exist or not?
                • cableties
                  • 35
                  Mail box icon with usb word
                  • canonbundy
                    • Jun 2012
                    • 607
                    Press Counter button and then device config. will show all accessories attached & installed.
                    • mido
                      • Nov 2011
                      • 177
                      the device configuration of the machine consist of the following:
                      Product Name: IR3235
                      Main Board version: 10
                      Controller Version: 2201.120.1502
                      Memory A Capacity MB: 256
                      Memory B Capacity MB : 512
                      Scanner Version: 1004.101
                      Finisher : 0.0.0.0.0.
                      OPtion:
                      cassette Feeding Unit -Y3
                      DADF - U1
                      PCL
                      UFRII
                      Super G3 fax Board-AC1
                      nothing mentioned about the USB
                      Is that mean the USB needs license to work??
                      • canonbundy
                        • Jun 2012
                        • 607
                        OPtion:
                        DADF - U1
                        PCL
                        UFRII
                        The fact that PCL-UFRII is displayed, means the Unit has an active Print License, you should be able to print files eg; Word, PDF etc from a USB Key.
                        • KL568
                          _
                          • Feb 2011
                          • 324
                          Nope, Canon office copier don't work that way, inclusive of the Advance range of copier.
                          For iR32 series, you need what Zoraldinho had indicated for that USB @ ControlPanel side to print PDF.
                          Those print license of PCL / UFRII are for print jobs via printer drivers installed in PC.
                          • teckat
                            • 16083
                            OPtion:
                            DADF - U1
                            PCL
                            UFRII
                            The optional USB Memory Connectivity Kit (LMS License) is required.
                            The optional PS Printer Kit-AA1 or Direct Print Kit-F1 is required to print from USB removable media for Base Model
                            the steps, and what is required, to print from a USB removable media
                            read pdf---------
                            USB Print.pdf
                            imageRUNNER 3245 / 3245i / 3235 / 3235i / 3230 / 3225
                            Direct Print to USB Functionality on the imageRUNNER 3245 Series
                            How you can print directly from a USB device to the imageRUNNER-
                            You can print files of a maximum size of 2 GB. 1. Press [Mail Box].
                            2. Press [Memory Media].
                            3. Select the memory media → press [Open].
                            4. Select the document to print → press [Print].
                            5. To print a PDF, JPEG or TIFF file, select the paper size, press [Done].
                            6. Press [Start Print].
                            In order for this function to work, you will need the following items. Please pay attention to the notes for each item since requirements may be different for specific models.
                            Item Description Item Number See Notes
                            Additional Memory Type A 512MB 2726B001AA 1
                            Direct Print Kit- F1 1542B004AA
                            PCL Print Kit - AA1 2722B002AA 1
                            PS Print Kit- AA1 2729B002AA 1, 2, 3
                            USB Memory Connectivity Kit-A1 2729B001AA 4
                            Note 1: Standard on the 3245i/3235i models and optional on the 3245/3235/3230/3225 models.
                            Note 2: Requires the PCL Printer Kit-AA1.
                            Note 3: Requires the Additional Memory Type A (512MB RAM).
                            Note 4 : Requires the PS Printer Kit-AA1 or Direct Print Kit-F1 on the 3245/3235/3230/3225 models for the 'print from USB Memory Media' function.
                            • canonbundy
                              • Jun 2012
                              • 607
                              My apologies to mido and thanks to KL568 & Teckat for their input on my above incorrect statement, it was based on the Toshiba 'Out of Box' Units being Print Ready and USB Print enabled (no Licenses required). Sorry.
