Can I remove an imagepass j1 option from a 3080 and put it in a 3080i ?
  • Simons
    • Jun 2008
    • 490
    Transfer Open interface board would be the main thing I would think. I understand the PCL would then not function. Just needing to FOR SURE that I can transfer to the i model without issue. I have some info that says yes but I would rather hear from someone who has proof.
    thanks!
    Re: Can I remove an imagepass j1 option from a 3080 and put it in a 3080i ?
    Yes you can just change img-cont to 3 on the one that will have the fiery fitted and change it back to zero on the 3080.
    • Simons
      • Jun 2008
      • 490
      Great to hear that I can transfer the Open interface board keep the advanced feature set of U send.
      • teckat
        • 16083
        thanks!
        Before Starting the Work
        set '3': in COPIER>OPTION>INTFACE> IMG-CONT. (This way, the appropriate IP
        address will automatically be setup for communication between the machine and its host machine.)
        read---------------J1_Installation.pdf
        firmware on 3080i must be MN-Cont 75.58 or later
        COLOUR UFR II/PCL
        PRINTER KIT-Q3 is already (Standard for i models)
        PDL PCL5c, PCL6, UFR II
        COLOUR UNIVERSAL
        SEND KIT-N1 (Standard for i models)
        COLOUR PS PRINTER KIT-Q3 (Optional for i models)
        imagePass J1 V1.1
        PDL Adobe PostScript 3, PCL 5c, PCL6
