paper not detect
  • anand8620
    • Jul 2012
    • 34
    [Misc] paper not detect
    Hi
    I am using Ir3300. from recent my machine is not detecting paper in (Tray 2).
    I have changed OPC DRUM, PCR, BLADE IN THE CATRIDGE from onwards 3 horizantal black lines in equal interval is coming. Please help me out in solving these two problems.
    Regards
    ANAND
  • kuby
    • Oct 2007
    • 1413
    Re: paper not detect
    1. broken ratchet gear on paper input unit. FB6-2778-000
    2. without seeing the images We can only speculate maybe dirty optics or scan glass.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Originally posted by anand8620
      Hi
      Regards
      ANAND
      Assuming that you mean it shows the drawer has no paper(empty) and not a failure to detect the paper size-- it will indeed be the ratchet gear (paper can't lift all the way up). Of course, you need to start by removing the cassette and checking to see if there is paper wadded up behind the drawer. If not replace the ratchet or the entire cassette feed assembly. Very common problem on this model.
      • Rachid.Akli
        • Oct 2011
        • 595
        Hi
        Regards
        ANAND
        Hello,
        There are two cases: 1- The tray paper lifting plate doesn't go up. ===> veify the lifting gear. ===>FB6-2778-000.
        2- The paper sensor lever may be broken. ===> FB6-2783-000.
        Rachid
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
