ir2270 gives zigzag in a copy
  • AIT MAMEUR
    • Jun 2008
    • 59
    hello, i have canon ir2270 which has this problem showing in this image. some one to help me. thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ir2270 gives zigzag in a copy
    It's sounds like the grounding spring for the steel registration roller not have a contact with the roller.Post a pic. please.
    • AIT MAMEUR
      • Jun 2008
      • 59
      i don't know at which level i can find this roller. please help.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Upload an image if you can.
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          my Algerian technician friend ...explain clear your problems ..her not meaning zigzag ....making some pictures to knowing your problems
          BEST TECHNICIAN . NICE PEOPLE .
          • teckat
            • 16083
            is it a paper fold issue=
            or a copy quality issue >like a wrinkles or creases=
            • zaza
              MECANOGRAPHE
              • Mar 2008
              • 1095
              this pictures mean it have bad press roller in fusion section ...if that ..you should be changing by other .
              • AIT MAMEUR
                • Jun 2008
                • 59
                hello, ok, here is my problem. thank you.
                • blazebusiness
                  SanDiegoCopierRepair.com
                  • 1257
                  Here's the pic you requested of that reg roller spring reg ground spring.jpg It's most likely a fuser issue though. Something to check....Is this problem happening when you make a copy from the glass or only when you use the Doc Feeder.
                  • teckat
                    • 16083
                    [ATTACH=CONFIG]19435[/ATTACH]
                    are u a tech
                    • zaza
                      MECANOGRAPHE
                      • Mar 2008
                      • 1095
                      Originally posted by teckat
                      are u a tech
                      troth my friend tackat ait memart is a pro technician from Algerian ...we are same technician ....
                      • AIT MAMEUR
                        • Jun 2008
                        • 59
                        Originally posted by blazebusiness
                        Here's the pic you requested of that reg roller spring [ATTACH=CONFIG]19436[/ATTACH] It's most likely a fuser issue though. Something to check....Is this problem happening when you make a copy from the glass or only when you use the Doc Feeder.
                        hello, the same symptom is done even when it is printing or copying. and let me say you what i have doing,
                        i have changed the right door, changed the developing assembly, the drum unit,
                        the problem, i have two machines which have the same symptoms. thank you for your patience.
                        • teckat
                          • 16083
                          Paper
                          • AIT MAMEUR
                            • Jun 2008
                            • 59
                            no no, i use the good quality.
                            • Brian8506
                              • 1665
                              Looks like hesitation at reg roller. Does machine have the door updates and gray vertical rollers? Any jamming problems? Hopefully you didn't swap parts between the 2 bad machines.
