ADF MARGIN IN IR3300
  • anand8620
    • Jul 2012
    • 34
    [Misc] ADF MARGIN IN IR3300
    Hi All
    1.I am using Cannon Ir3300. When I use to take the copy from ADF it is giving me 9r percent of the original in legal copy. How can calibrate?
    2.Is it possible to run this machine with INVERTER SUPPORt, If so How much KV is required.
    Regards
    ANAND
  • teckat
    • 16083
    Re: ADF MARGIN IN IR3300
    Originally posted by anand8620
    Hi All
    Regards
    ANAND
    U mean LGL US size ?
    what is exact size of original ??
    what is paper size in trays ?/
    in service mode----------------------
    COPIER > OPTION > BODY>SCANSLCT
    SCANSLCT
    Use it to enable or disable the original size detection mechanism for the ADF.
    • When enabled, the scan size is determined in relation to the original size.
    Settings 0: off (default), 1: on
    also-------
    COPIER>OPTION>USER>SIZE-DET
    SIZE-DET
    Use it to enable or disable the original size detection function.
    Settings 0: enable (default), 1: disable
    Caution -After making a selection, turn off and then on the main power switch.
    • Tze Chian
      • Feb 2013
      • 36
      Regarding to this picture. I already try copy from platen,is looks normal even print out from machine also ok. Just only ADF the end of the paper is blank.
      Is it can solve it from service mode?
      front paper is original, behind it is copy output from ADF.
      • teckat
        • 16083
        [QUOTE=Tze Chian;355837]Regarding to this picture. I already try copy from platen,is looks normal even print out from machine also ok. Just only ADF the end of the paper is blank.
        front paper is original, behind it is copy output from ADF.[/QUOTE
        is this on a 3300 printer DADF H1
        make certain that Copier>Option>Body>ORG-LTR is set to '0'.
        SEE PDF>> READ PAGE 5 FOR ADJUSTMENTS ON REAR EDGE REGISTRATION ADJ.
        DADF-H1 Installation Procedure.pdf
        • Tze Chian
          • Feb 2013
          • 36
          Guys,You know what. the setting once i adjust it. notthing happen, after i re-adjust it back to previous setting. DONE...=.= Maybe that machine gonna say goodbye already.
          But how about if i print,platen copy & DADF copy also like the sample i post? Thx very much.
          • teckat
            • 16083
            bottom line>>> does it work ?
            what adjustment did u follow
            • Tze Chian
              • Feb 2013
              • 36
              If print,platen & ADF copy alignment problem i haven test yet. But the ADf problem i asked few day ago,i tried from step D to F. But nothing happen,so i re-adjust it back to previous and test... back to normal.
              New problem i faced on iR3300 again, Err E514, i checked S/Manual,it show deliverly motor faulty. Guys gt the assembly part manual?
              • teckat
                • 16083
                Finisher-J1
                E514 (M2)
                Saddle Finisher-G1
                E514 (M3)
                • Tze Chian
                  • Feb 2013
                  • 36
                  Originally posted by teckat
                  Finisher-J1
                  E514 (M2)
                  Saddle Finisher-G1
                  E514 (M3)
                  Finisher-J1, i refer to the S.M it show is stack handling motor. But whr is the motor?
                  • teckat
                    • 16083
                    The stack handling motor (M2) is a 4-phase stepping motor.
                    FH6-1859-000
                    funny thing> this motor is also called/used for Stack tray lift
                      • 22999
                      Gosh. It looks just lovely to get to. =^..^=
