canon image runner 4570
  • josephmeza
    • Oct 2012
    • 12
    [Jamming] canon image runner 4570
    I have a canon image runner 4570 it jams and missfeeds all the time from tray 1, I need to order all the feed rollers for tray 1, also need part #'s
    now this happens only in the morning for tray 2 frst few atempts it may jam and missfeeds but it seems after it warms up it feed fine
    out of tray 2 the rest of the day. please help I don't normally work on canon products and thanks in advance for all your help
  • Herrmann
    • Jan 2006
    • 792
    Re: canon image runner 4570
    maybe this technical info is useful for you:
    ir4570-032.pdf
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • josephmeza
      • Oct 2012
      • 12
      thank you very much, I will check this and let you know if that took care of it
      • northernlife
        • Sep 2011
        • 847
        If you open the side cover and grab the black plastic guide that the paper comes up from. if you tug on both the front and the back you'll feel the front usually has a lot more play. Irregular pressure on rollers will lead to misfeeds. These were fun to figure out when they first got released. I'm assuming there's a fresh set of rollers in tray 1.
        • josephmeza
          • Oct 2012
          • 12
          I will check that, thank you for our help
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            Jam code??
            If you have jams only in the morning open right door and remove flapper rubber from the picture.You have the black one.
              • 23006
              Originally posted by zoraldinho
              Jam code??
              [ATTACH=CONFIG]19590[/ATTACH]
              zoraldinho beat me to the punch. If it's jam code 0108 on the first print of the day, just change those little foam pads.They've gone sticky. I usually use a single hole punch to make a couple 8mm disks of inner tube rubber. Remove the old pads and secure the new ones with superglue. =^..^=
              • canonbundy
                • Jun 2012
                • 607
                Maybe replace the Foam Strip along the Upper Door (it applies pressure to the Tray 1 Vertical Feed Rollers only), if the strip has permanent guide indents then it is not working.
                • charm5496
                  • 2387
                  There are mods for the vretical path roller, inner door assembly and lower right door that are permanent and you don't have to worry about them. I haven't done a foam pad on this model in 6 years now maybe.
