cannon 5570 error code E025-001
  • satish.ambiger
    • Aug 2012
    • 24
    [Error Code] cannon 5570 error code E025-001
    Hello
    I have cannon 5570 which is showing error code E025-001. And i have changed the bottle feeder motor but the problem remains please help.
  • canonbundy
    • Jun 2012
    • 607
    Re: cannon 5570 error code E025-001
    Originally posted by satish.ambiger
    Hello
    Sub Drive Assy. FM2-3029-000
    Bottle Drive Assy. FM2-3024-000
    • satish.ambiger
      • Aug 2012
      • 24
      Please tell me which motor is to be replaced, for E0025-0001, upper one or lower one
      Thanks in advance
      • vigour
        • Aug 2010
        • 1038
        He told you.
        Sub drive assembly, which contains the lower motor .
        It is much easier to change, and cost a few dollars more than the motor only
        • satish.ambiger
          • Aug 2012
          • 24
          Thanks to
          canonbundy
          and
          Vigour
          • Tonersniffer
            • Nov 2012
            • 74
            3 things cause this:
            User puts in toner wrong
            Lower motor FK2-0813-000
            Fuse on top middle of Dc Controller blows.
            Lower motor is easy to replace.
            I stock the motor and the fuse to fix this error.
            Motor check 20 or 21 (forward or reverse) in Service mode will help.
            Tom
