CANON IR2520
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Error Code] CANON IR2520
    hello we have error code **E000808-0000 in canon ir2520 ..please help
    BEST TECHNICIAN . NICE PEOPLE .
  • teckat
    • 16083
    Re: CANON IR2520
    were u working on fixing unit ??
    may be bad wall voltage
    one of the connectors for the fixing assembly not being plugged in when the unit is powered on.
    check them> then unplug the machine for about 10 minutes. see if clears
    E808 0000 Fixing drive circuit failure
    • The heater does not turn on.
    • A fixing drive motor failure was detected.
    • Check the connector of the fixing film unit.
    • Replace the fixing film unit.
    • Replace the fixing drive motor.
    • Replace the DC controller PCB.
    • Replace the power supply PCB.
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      Re: CANON IR2520
      thx friend nick ..a good reply from yourself by the costumer was said me l buying this new machine and l buying the new adf ....firstly the copier function very good but if he placed this new adf at this machine this error code appeared there ..in your opinion if we put them the new adf we should be uploaded a new driver ?
      • teckat
        • 16083
        Re: CANON IR2520
        u mean when he plugs the DADF into printer ,it codes out to e808 ,
        what does DADF have to do with a driver
        is this a new or refurb ?
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          Re: CANON IR2520
          so the costumer was said me . he buying this new adf but he not found any dvd driver ..what can do it ?
          • teckat
            • 16083
            Re: CANON IR2520
            do not understand
            • Rachid.Akli
              • Oct 2011
              • 595
              Re: CANON IR2520
              The DADF installation doesn't need any driver or system software. It is just a hardware installation. Have you seen the machine or you're just reporting what has said your custmer?
              Rachid.
              "Find a job you love and you’ll never have to work a day in your life." Nagy's father
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                Re: CANON IR2520
                Rachid.
                hey men this costumer was buying this machine from capital Alger ..in some workshop in cheragua ....it's news if this costumer was function this ir2520 it have this error code ...l think it is your personal workshop's or you knowing there cause you live in capital of Algeria try found this workshop maybe you can controlled her machine ....good lucky .
                • DAG COPIERS & COMPUTERS
                  • Oct 2010
                  • 860
                  Re: CANON IR2520
                  do not understand
                  Hi zaza, try to post the question in French. I think Rachid Akli can help translate in English for the forum, or we can 'Google Translate'. It will make the members help you better.
                  • northernlife
                    • Sep 2011
                    • 847
                    Re: CANON IR2520
                    Je suis francais si ca l'aide
                    • Rachid.Akli
                      • Oct 2011
                      • 595
                      Re: CANON IR2520
                      It's a mess my friend!!!!!!
                      Rachid
                      • Billy
                        Re: CANON IR2520
