Canon iR-C5180in Scan to email
  • AlSyed
    NewBee
    • Aug 2010
    • 41
    [Misc] Canon iR-C5180in Scan to email
    Dear Friends,
    I have enough knowledge to setup Konica Minolta Scan-SMB and Scan-email. Canon is quite different. This client have a Canon iR-C5180in as a copier/printer and want me to setup Scan-email as well. Would some one kindly give me steps to follow to setup this Scan-email. Will be greatly appreciated.
  • teckat
    • 16076
    Re: Canon iR-C5180in Scan to email
    Originally posted by AlSyed
    Dear Friends,
    Setting up Scan to Email.pdf
    Setting up Scan to File.pdf
    At the copier:
    Additional Functions-> System Settings-> E-mail/I-Fax Settings.
    From the RUI
    Enter copier's IP address in web browser-> Additional Functions-> Custom Settings-> E-Mail/I-Fax
    SMTP Server -
    Enter your Exchange server's IP address
    E-mail Address-Enter any e-mail address, example ourcopier@mydomain.com (this will show up as the sender)
    POP Server- Leave blank
    POP Address- Leave blank
    POP Password- Leave blank
    Auth./Encryption
    User/Password- Valid user/pass for exchange server
    Allow SSL[SMTP]- if applicable, If you need to change the SSL port it is done in service mode.
    Scan to e-Mail
    1- SMTP server u can name ( mail.myisp.com ) or ip address
    2- Default Gateway
    3- DNS server address
    4- A valid email address must be assigned to the machine put the address in both the machine address and the administrator address locations
    5- If they are on a Domain put the domain in the DNS Domain ( mycompany.com ) After entering all of the above correctly reboot machine, and test. The above assumes that your machine is already on the network and you can print and brows to it, and the SMTP does not require Authentication.
    • AlSyed
      NewBee
      • Aug 2010
      • 41
      It may not get easier then this and I hope I will be able to set it up. So Many Thanks to you.
