IR5000i system software V9.01
  • charrex1
    • Feb 2013
    • 17
    [Misc] IR5000i system software V9.01
    I hate to ask for software here, but since this a very old version I hope you guys don't mind.
    I have several IR5000i's, with dying hard drives, which don't have the Controller Upgrade Kits and will not accept any newer version of system software. Upon investigation, I found that the newest version they will accept is 9.01. I don't have access to any controller upgrade kits, so I need to try and find software they like. Does anyone have an older version, 9.01 or earlier, that they could please post for me? I would greatly appreciate any help you could give me. Thanks a lot in advance.
  • charm5496
    • 2387
    Re: IR5000i system software V9.01
    the 5000i is an A2 type controller. It was released after the A1 controller was "upgraded". You should be able to install the 48.02 which came out back in 2009 wihtout any issues.
    • charrex1
      • Feb 2013
      • 17
      No, I did try to load 48.02, but it fails. At first it warns me that the machine does not have the upgrade kit and if I proceed anyway, the machine gets 746 error code which indicates the wrong software. Thank you for the input.
      • vigour
        • Aug 2010
        • 1038
        I think he is right V9.01 is the latest we have posted.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Paging Doctor Paul, paging Doctor Paul!
          • teckat
            • 16083
            5000i/ with no kit
            v9.01 came out in 1/2005
            before that was v8.01 in 8/2004
            u need to look in the C:\Canon File Folder\SST System Software Folder\SST Files\iR5000i_v48.02 folder for
            iR5000i_v48.02\iR5000iN_v09.01
            the v48.02 has the v9.01 firmware folder in it> when unzipped> & downloaded to C:\Canon File Folder\SST System Software Folder\SST Files
            it was probably never registered in SST when u or someone registered the v48.02
            it was part of the original v48.02 firmware folder/
            see original tech pub/
            v48.02_v9.01.pdf
            original release was in a ISO file u burned to a CD/ or purchased from Canon in 2008-
            Canon no longer requires or publishes the ISO
            • charrex1
              • Feb 2013
              • 17
              Thanks for the input guys, but I just managed to get the software from a friend I used to work with. I tested it and it seems to work fine. Thanks for your time and words of wisdom.
              • teckat
                • 16083
                • canonservis
                  • Jul 2014
                  • 3
                  Hi,
                  I have an access to firmware downloads but i can not find ver 9.01 there. we have a customer with IR5000i which we have upgraded to ver 48 and now E746 is there. Can anybody help me with download location for ver 9.01?
                  Thank you in advance
                  Nixon Cservis
                  • lubson
                    • zoraldinho
                      teacher-guide-expert-guru
                      • Mar 2008
                      • 5017
                      IR5000i-v45,01 is my oldest.
