NP6521 Dark copies
  • hellcat
    • Jan 2012
    • 124
    NP6521 Dark copies
    I know this thing is ancient and I don't know much about the old analog series machine. This machine has about 280K copies. Fuser looks fine, sponge corona looks fine.
    The drum looks decent. I did notice the developing/toner unit does not look like its coating the roller properly. (Again not sure this is normal on this unit) Took a few pictures of what the copies look like and the developer/toner unit. Anything else I should check?
    This is a picture of a Blank Page
    This is a picture of a copy
    This is the developer/toner unit
  • teckat
    • 16083
    Re: NP6521 Dark copies
    try this>>
    remove dev metal roller> wipe off> then use metal cleaner (BRASSO) and a green no scratch pad> clean up good> wipe down w/dry rag> then clean off with alcohol damp rag> use dry cloth to clean off
    good luck/ How about getting a used / useful B & W Canon printer
      • 22999
      It looks to me like you may have a mixture of OEM and generic toner in the developing unit. They do not mix well.
      Clean the developing unit like teckat suggests, vaccum it out completely, then install OEM toner. That should resolve your issue. =^..^=
      • livancicm
        • Sep 2008
        • 96
        is optic clean
        • teckat
          • 16083
          Originally posted by livancicm
          is optic clean
          Optic clean enough to reflect the SUN > will not help that shown Dev Cylinder
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
