Canon CLC 3220 Printer Setup Information
  • sonyboy
    Rookie Blue
    • Mar 2013
    • 26
    #16
    Re: Canon CLC 3220 Printer Setup Information
    I checked the destination address restrictions and there are none there...
    I plugged in the cable on a smaller "one page a time" fax machine and sent the documents and they were delivered fine.. even sent a test fax to myself and it delivered fine..
    Not sure, where the problem is, i checked the logs on System Monitor >> Send and the status of the faxes is "waiting" ..
    Usually, when i fax something it will give a tone , then dial the number then some funny tone and the fax is delivered , now its silent.. Only one beep when it gives the error..
    I tried googling it but could not see any answers to that solution...
    Edit:
    Could it be that the faxing thing needs to be reset on the printer? Im not sure, never set it the first time not that i know how but i just plugged in the cable and was faxing away..
    A Picture Is Worth A Thousand Words !!!
    • sonyboy
      Rookie Blue
      • Mar 2013
      • 26
      #17
      Originally posted by teckat
      do u know how to access the 3220 service mode ??
      first make sure to follow the C1 install instructions/
      pay attention about when to connect the cables
      do u have a G3 Fax in printer ??
      instead of setup.exe
      I would use the
      PCL5e-c_v14.00_INF.exe
      PCL6_v6.90_Win2k-Win7_INF.exe
      Fax_v8.85_INF.exe
      Aweah, does anyone have an updated link to these drivers ?
      The links don't seem to be working anymore ..
      • teckat
        • 16083
        #18
        Canon U.S.A. : Support & Drivers : imagePASS-C1
        _____
        CLC3200/3220-C1 v2
        CLC3220-C2
        • sonyboy
          Rookie Blue
          • Mar 2013
          • 26
          #19
          Thanks a lot teckat for these , tell me, do you think these drivers will work on a Canon CLC 3220N without a "fiery" in the back (don't sure if thats the correct name)
