canon ir1025 cq bleeding on trail edge side of bold areas
  • skibum
    Independent Service Tech
    • 231
    [CQ] canon ir1025 cq bleeding on trail edge side of bold areas
    This machine has genuine toner, new Canon drum and oem new developer unit and still puts out a repeated image lighter than the primary image about 2mm from the primary image on the trail edge side. This is most noticeable in bold areas where there is a lot of black. It makes the image look blurry. Has anyone had this problem on this machine.
  • Gadget29
    • Mar 2013
    • 12
    Re: canon ir1025 cq bleeding on trail edge side of bold areas
    What's the count on the machine? Could it possibly be fuser related?
    • teckat
      • 16083
      post an example image
      is this when using ADF
      How are test prints ? and Glass Prints if ADF does not apply ?
      Remove the Transfer Assembly from the imageRUNNER and inspect the ground tab on the bottom of the assembly. -make sure Ground Tab clip did not fall off leaving the Grounding Tab unsecured.
      • skibum
        • 231
        It does it on prints as well. I have stopped the machine (panick stopped) and it has the problem before reaching the fuser. The transfer idea sounds more possible.
        Thanks.
        • skibum
          • 231
          Please see image in attachment. This is not happening in the fuser. I stopped the machine before it reached the fuser and it has this image right off the drum. copy or print
          • skibum
            • 231
            Please see my attachment. This is copy or print. This copier has 64K on it. Have you ever seen anything like this.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Could be laser??
              • teckat
                • 16083
                if image is on DRUM before transfer >
                check>
                replace Image processor and/or replace the Laser Unit.
                • skibum
                  • 231
                  Problem solved, and the winner is Teckat (ground was in fact missing under tranfer guide assembly and caused the problem). I used a paper clip and used the screw already there to thread it in until new part comes in.
                  Thanks to all that helped, all gave alot of good info.
                  • teckat
                    • 16083
