I have a Canon CLC1180 with a ColorPASS z500 fiery. I badly need to print from windows 7. I have the driver in my Server 2003 but I still need a driver. Can anyone help?
colorPASS z500 print driver for Windows 7
Re: colorPASS z500 print driver for Windows 7
No Win 7 Driver
this may help---Canon Driver Configuration Tool
http://www.copytechnet.com/forums/ca...tool-cdct.html**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
You may have some success in using a driver for a newer Fiery RIP, that has driver for Windows 7.
"PostScript is PostScript", at least to some degree, anyway.
There may be more features in the newer drivers that you won't be able to use, but at least you'll get output.
The driver configuration tool that Tekcat mentioned is a wonderful tool, but I don't think it will work with Fiery drivers. (Fiery drivers can get weird.) Good to keep in you back pocket, though!“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
