Problem copy from ADF canon ir3300
  • teckat
    • 16083
    #16
    Re: Problem copy from ADF canon ir3300
    Originally posted by udayan
    Dear I am not a tech. in the ADF settings I will post the picture afterwords.
    I can't get the page size in ADF settings as I seen in the videos, i think it is some software or other settings problem. If possible can you please help me.
    Udayan
    PS : where i get size sensors in the ADF, i have no idea, is the top panel where some plastic trangle parts are coming out to detect the paper.
    see pdf's
      Udayan
      I'm done
      Outta here
      Not your damn Dear either
      • udayan
        • Aug 2018
        • 9
        #18
        I'm done
        Outta here
        Thanks a lot Sir,
        I will try this and let you know the results.
        Regards,
        Udayan
        • udayan
          • Aug 2018
          • 9
          #19
          Thanks a lot Sir,
          This are my photos from the canon IR3300.
          only one paper type display here J-B5R
          Regards,
          Udayan
          • teckat
            • 16083
            #20
            [ATTACH=CONFIG]42354[/ATTACH][ATTACH=CONFIG]42355[/ATTACH]
            FEEDER>OPTION
            FEEDER
            SIZE-SW
            Use it to enable or disable detection of mixed original sizes (AB and Inch sizes).
            Settings 0: disable (default), 1: enable
            It is at 1 --- do u use mixed sizes in ADF ?
            ================================================== ================FEEDER>DISPLAY
            FEEDER
            FEEDSIZE
            Indicates the size of the original detected by the ADF.
            J-B5R
            Only one size is displayed here -----move the ADF slide guide --- see if it changes
            is there paper in ADF tray ??
            • kashif
              • Apr 2013
              • 45
              #21
              Originally posted by bua99
              Dear all,
              I have problem with my canon ir3300, if copy in plate glass it's good,
              But, when i copy from ADF, the margin different with original, it's different about 3 cm then original.
              Notes: i use paper 215x330 cm.
              Thx for your help.
              from the setting you can check paper size, some one sent you video same procedure.
