Canon PC 940 jam light won't clear
  • copiersrockdude
    [Jamming] Canon PC 940 jam light won't clear
    ok , i can't believe i'm even posting this, but if i can fix it i may have a decent sale coming out of this.
    checked all sensors , registration and fuser all clear and operating i only see 2 in the machine am i missing anything here.
    i think i remember a while back that if the thermistor went, it would do something like this and not clear..
    i haven't worked on one of these in a loooong time.....lol....
    • 16083
    Re: Canon PC 940 jam light won't clear
    Power up> remove cover>Unplug connectors on DC CONTROLLER one at a time/ see if jam indicator goes out >
    > note the connector
    Sensor Check.pdf
    Jam Message.pdf
    • Canon.Tech
      • Mar 2009
      • 335
      I've had the yellow fixing shutter warp & obstruct the exit sensor arm & that arm too can crack/break & are you sure the reg sensor arm is moving feely & that there is not a pile of toner in the sensor?
      • Brian8506
        • 1665
        Theres a sensor in the bypass assembly of all places. I've had them get knocked out of place and that will give a false jam code.
        • copiersrockdude
          thanks lads , it was the bypass sensor little bugger was knocked out of position..
          man i can't believe i didn't see that....oh well its "miller time"...i'm buying......lol...
          • Brian8506
            • 1665
            Remember itsalways 12 pm somewhere
