Error code e602-0001 - IR 2270
  • Mohan Singh
    Hi All,
    Thanks for you previous help as PDF for fusing assembly PDF.
    I am not sure whether I am in a problem or not .. but it seems to be at the moment.
    Faced Error -- E00007-000 initially -- Fixing film issue ->> It got changed to E00001-000 -- unwanted heating ->> Now as I have removed the error from service mode -->> it is showing Error Code - E602-0001
    Can sombody help.
    Rgds,
    Mohan
  • HP:guy
    • Feb 2013
    • 279
    Re: Error code e602-0001 - IR 2270
    Hard drive error.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Replace hard disk and reload firmware using the SST, HD-format file & firmware.
      • nochick
        • Jan 2012
        • 80
        try to re plug harddisk first .....
        then change the new one
        Good luck
        • mido
          • Nov 2011
          • 177
          This code means an error on the hard disk has occurred and can't be detected,
          • Mohan Singh
            Hi All,
            I have learnt that ignoring error via service mode has result the hard disk to crash.
            Later on running chk dsk by pressing 1 and 9 and get the copier turned on -- didn't help
            It has costed me 1800/- India Rupees..
            Now if any of you can guide me if I can recover and get the disk working.
            What are the steps and where can I get the ROM and applications.
            If any one in India Delhi .. can help me in recovering this hard disk.
            • sharptech1
              • Oct 2011
              • 163
              CAN9N
