Hello, i have an issue whit this machine in particular...first when i see the machine at the first time it was whit the code error e602-0002, i can't enter on secure mode (1-7) so i changed the hdd and the code error e355-0002 appears, please how can i fixed? I don't kwon if any of pcb or main controller,etc was changed...thanks for your help.
Irc5180 e602-0002 then e355-0002
Re: Irc5180 e602-0002 then e355-0002
this HDD u put in > where did it come from ?
New or Used HDD's need to first be formatted inside printer using the Cannon SST
u then need to load the 5180 Firmware from the SST program
e355 is a Error of the Serial PCB error/ may be because there is no operation firmware on HDD
Mismatch of serial numbers of three items:
ECO ID PCB, Main Controller PCB (SRAM) and Counter Memory PCB.
1. Put back all original PCBs into the equipment!
2. Do not utilize a used Counter Memory PCB or ECO ID PCB from any other equipment.
WAS SOMEONE SWAPPING PCB's?
The Counter Memory PCB, ECO ID PCB and SRAM PCB retain information pertinent to the specific engine they are installed in. Ensure that you never swap any of these circuit boards with another engine.Last edited by teckat; 04-05-2013, 06:09 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
this hdd u put in > where did it come from ?
New or used hdd's need to first be formatted inside printer using the cannon sst
u then need to load the 5180 firmware from the sst program
e355 is a error of the serial pcb error/ may be because there is no operation firmware on hdd
mismatch of serial numbers of three items:
eco id pcb, main controller pcb (sram) and counter memory pcb.
1. Put back all original pcbs into the equipment!
2. Do not utilize a used counter memory pcb or eco id pcb from any other equipment.
was someone swapping pcb's?
The counter memory pcb, eco id pcb and sram pcb retain information pertinent to the specific engine they are installed in. Ensure that you never swap any of these circuit boards with another engine.
that's the problem...the rear cover was manipulated so maybe some were changed...how can i know if this happened?....and other thing the hdd is from an irc4080, i re-install firmware with the sst but the error code e355 still appearing...there is a way to know if something has changed?...thanks for the help.Comment
if this will not work u have a BIG HEADACHE / to find out who was swapping pcb's
E355 is displayed, enter Service Mode Level 3 and perform
an E355 Clear as follows:
Additional Functions button then #2 & #8 keys simultaneously>then Additional Functions button
Additional Functions button again> then #1 & # 9 keys simultaneously> then #3 key
COPIER>FUNCTION>CLEAR>E355-CLR
Turn OFF and then ON the equipment
DO NOT
ADJUST ANYTHING ELSE IN THE SERVICE MODE LEVEL! Doing so will have an adverse affect
on the engine
SERVICE MODE LEVEL 3 SHOULD ONLY BE UTILIZED FOR AN E354 or E355 CLEAR!
TAMPERING WITH OTHER MODES IN THIS LEVEL MAY NEGATIVELY IMPACT ENGINE PERFORMANCE**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
