Lubricating the gears in Canon IR 3300
  • kishore
    • May 2025
    [Misc] Lubricating the gears in Canon IR 3300
    Hello,
    I have a canon 3300 copier , can any one suggest me the better product to lubricate the gears in it ,
    Thanks in advance ,
    Kishore
  • mr.daus
    • Apr 2011
    • 98
    Re: Lubricating the gears in Canon IR 3300
    Originally posted by kishore
    Hello,
    Thanks in advance ,
    Kishore
    gears on the machine does not need to use much less oil lubrication, use a lubricant pasta and it did not take much because the material is made of plastic gear
    firdaus +(62)8195002007 firdaustrish@ymail.com
    • teckat
      • 16083
      Hello,
      Thanks in advance ,
      Kishore
      i never lube vinyl gears/ but Canon has come out with a pub on lube-
      the gear friction (heat) from lube will deposit BLACK GUNK on gears
      CANON
      following three types of lubricant should be used as a substitute for MOLYKOTE PG-641, each of which needs to be used according to the appropriate location and use:
      Super Lube Grease--Semisolid=FY9-6005-000
      USE-Plastic,Rubber,Resin,Metal (Normal temperature and low pressure location)
      G-50000H--Semisolid=FY9-6022-000
      USE--Plastic,Rubber,Metal (Normal temperature and low pressure location)
      MOLYKOTE G-8022=FY9-6026-000
      USE--Metal (High temperature and high pressure location)
      • Be sure to clean old grease off using a lint free cloth moistened with alcohol prior to applying new
      grease.
      On some equipment models, there are areas where applying grease is prohibited. For these situations, a Technical Publication will be released advising as such.
      It pays to know your model and it's recommended maintenance
      when in doubt / don't use lube
        • 22932
        I'll agree with teckat on this.
        The majority of non-metallic gears on copiers are made of delrin (aka polyoxymethylene: Polyoxymethylene - Wikipedia, the free encyclopedia ). They need very little lubrication in most applications. Thick lubricants mostly tend to collect particulate (toner, dirt, whatever is handy) to create a thick paste that binds up the gear drive.
        Like all rules there are exceptions. The first exception is squeaky or squealing gears, usually at the gear bore. A single drop of light oil will quiet it down nicely. (Not the gear teeth surface)
        The second exception is gears that are near a heat source like the fuser. Uniflor 8172 works best in applications near the fuser. Like before I do not lubricate the gear teeth, only the gear bore and bushings, and only if they are noisy. HP style fixing films always require lubrication, also Uniflor 8172.
        Tech Aids: Lubricants - Precision Roller
        • kishore
          Thank you very much for your suggestions..
