IR3045 image fading
  • bineshpaul
    • Jul 2010
    • 43
    IR3045 image fading
    Hi. kindly advise me how to isolate my problem of ir3045. After mounding the Hopper assembly the image is fading. Due to the error code of E20 I have unmounted the Hopper assembly . Now the there is no error code but the copy and print comes too light.Thanks in advanceBinesh
  • teckat
    • 16081
    Re: IR3045 image fading
    How do u expect a printer to function without a hopper
    post the correct error code e020 ?
    check the developer unit auger
    E020 = The error code occurs when the developing assembly toner sensor (TS1) indicates no toner is detected in the developing assembly while the hopper toner level sensor (TS2) indicates toner is present in the sub hopper. After approximately 388 seconds the error code will display.
    The toner sensors can be checked in I/O mode. To check the TS1 sensor go to I/O>DC-CON>P021 bit 1. Toner being detected will indicate "1." The TS2 sensor can be checked at I/O>DC-CON>P030 bit3. Toner being detected will indicate "1."
    • Mina Banoub
      • May 2011
      • 50
      I think it has nothing to do with the hopper assembly as long as the developing ass`y contains toner. Any way, Try to execute the following {service mode > copier> function > Part-chk > MTR > (enter 5) and press (ok) } does the toner bottle rotates ?
      • bineshpaul
        • Jul 2010
        • 43
        Originally posted by teckat
        ----------How do u expect a printer to function without a hopperpost the correct error code e020 ?check the developer unit augerE020 = The error code occurs when the developing assembly toner sensor (TS1) indicates no toner is detected in the developing assembly while the hopper toner level sensor (TS2) indicates toner is present in the sub hopper. After approximately 388 seconds the error code will display. The toner sensors can be checked in I/O mode. To check the TS1 sensor go to I/O>DC-CON>P021 bit 1. Toner being detected will indicate "1." The TS2 sensor can be checked at I/O>DC-CON>P030 bit3. Toner being detected will indicate "1."
        MR. Teckat, when the machine shows the error code of E20 0000 I discussed with one of my friend, he told me that toner may be clogged in the hopper assembly. so i decided to check the hopper assembly. Now the error code is gone, the problem is light copy. top side of the paper is blank paper and the bottom is ok. the same problem when is giving print also. scanned image is attached herewith. I hope you may solve my problem.RegardsBinesh
        • HP:guy
          • Feb 2013
          • 279
          It looks like the developer is not full of toner. did you go to functions >install> tonerS.
          run that to make sure the developer is full.
          • teckat
            • 16081
            DID U CHECK THE IMAGE ON THE DRUM BEFORE TRANSFER (do a panic stop)
            Image Density Is Light on the Rear Side of the Copy
            Re-seat transfer roller and confirm correct pressure.
            Check the front and rear transfer arms for proper positioning// each end of the transfer roller should "spring back" after being pressed. If the roller is not positioned correctly, check that the springs on each end are in place.
            I fthere is a bind from a metal roller in a plastic bracket, it is recommended to replace the plastic part as it may have been damaged and will allow the symptom to return.
            also---
            Make sure the developing assembly is receiving correct cam pressure.
            (check the bushings)
            Check Dev spacers
            • bineshpaul
              • Jul 2010
              • 43
              also---
              Check Dev spacers
              thanks teckat I found that developing assembly is not receiving correct pressire.
              thanks alot
              Regards
              Binesh
              • teckat
                • 16081
