Hi guys,
I have a problem with the lower sort tray of the finisher V1. The controller board has two red led's next to the connectors which connect the respective upper and lower paper output trays.When the finisher is powered on both the leds come on the led connected with the upper tray stays brightly lit where as the led connected with the lower tray comes on bright and then fades away. The finisher functions only with the upper output tray where as the lower tray remains in-active the machine does not throw up any errors, works normally with the upper tray.Any suggestions ,help guys??
thanks
thanks
