Ok customer admit he was using duplicate toner, working well until it started giving blank copies. Removed and cleaned the developer and put fresh OEM toner GR-22. But now machine displays 'Out of toner', then followed by 'Change toner'. I don't see any obvious cause for this. Dev. unit seem to make proper contact(or is it?) with the HV in the machine. For now I am stuck, any suggestions will be of great relief to us. Thanks in advance.
iR 1022 B&W, display message: out of toner, change toner.
Tags: None
Re: iR 1022 B&W, display message: out of toner, change toner.
During toner supply to the developing assembly, the inside part of the toner bottle rotates and allows toner transfer to the dev. Verify the following:
1- If the dev assembly is full of toner, then, you have a toner detection issue. Clean and verify the contacts, replace the dev assy or the Dc controller.
2- If the dev assembly is empty, you have a toner supply problem: Verify the toner bottle driving system which is in the rear side of the dev assy.
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's father -
Hello,
Rachid.Comment
