Hi there guys, I have a problem with a Canon IR1025n, first the problem was the Fuser Teflon slide, I did change with no problem, so, when the machine when the copier was armed, did not return to light, and the screen just stays black, with small points, all cables and membranes were put in place, but not on, do not rotate the gears, or initialized.
In advance thank you for your help, if you need more details please do not hesitate to ask. Thank you again.
