IR5055 and dark bands
  • landspeeder
    • Feb 2010
    • 355
    So I had one with black stripes on the printouts..copies or print jobs were the same...I pulled the dev and drum and found a build up of waste toner on the blade where the waste toner tube is...this build up was stopping the waste toner from being sent to the bottle and was being put on the drum so the stripes...I cleaned the tube out etc. put it together and it works nice...I checked the waste bottle and its less than 1/2 full...so my question is why the build up..bad motor?...but wouldnt that throw a error....hmmm one other thing the display says the toner waste bottle is almost full but dont change yet..like I say the bottle is less than 1/2 full...how can I get rid of the error..it bugs the customer....or is this part of the problem
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • HP:guy
    • Feb 2013
    • 279
    Re: IR5055 and dark bands
    This is Canons' problem for years, not enough air between the fuser and the AP unit.
    Thus toner chunks. possible firmware upgrade will help.
    • Brian8506
      • 1665
      You may have to clean out the toner that has hardened up by the auger and hopefully it didnt break. Did you turn the cleaning unit to see if the auger was turning? There is always some toner in that unit as well as the mag cylinder. Clear the misc counter in service mode. That message pops up every 250k
      • landspeeder
        • Feb 2010
        • 355
        Im pretty sure the auger was turning .....anyway to check without pulling it apart ?
        thanks
        • Brian8506
          • 1665
          Take cleaner blade assembly off top and turn gear cluster on front
          thanks
          • landspeeder
            • Feb 2010
            • 355
            Perfect ...i have to wait to Monday and i will check it out ....have a great one !
            • vigour
              • Aug 2010
              • 1038
              After clearing out your chunks, CLEAN OR REPLACE YOUR CLOGGED PRIMARY FAN FILTER. Check your ozone filter too
              Lack of airflow
              Too much heat.
              • landspeeder
                • Feb 2010
                • 355
                Lack of airflow
                Too much heat.
                I noticed that the filters looked ugly ...thanks for the tip! have a great one !
