One more question, regarding installing nethawk driver
  • nfl2k1
    i tried with four different computer.
    Whenever i tried to install nethawk driver, it makes my computer freezed.
    So i tried it with four different brand computer.
    1. Dell desktop
    2. Fujitsu Lifebook
    3. HP Desktop
    4. Dell Inspiron notebook
    results are all same. Whenever i install this driver, it freezed..
    Is anyone knows why? if yes, then please let me know how to solve this problem T.T Tahnks
  • yourownfree
    • Dec 2007
    • 474
    see attached file for instructions to install. after install you do not mess with it. it automatically detects your usb-parallel cable when plugged in, but you will need to select it as the last thing before you start downloading from your sst. From your sst window, no where else.
    • Starion
      Tech
      • 58
      having a problem with installing this too..
      The nethawk installs as "usb printing support" but when i go update driver and then go to C:\Program Files\ServiceSupportTool\inf\USBPAdp it says a better driver could not be found than the one already installed or something like that..
      Any ideas?? have only had it working on windows ME on my old laptop lol..
      • Oze
        Ricoh Fanboy
        • 1663
        The nethawk installs as "usb printing support" but when i go update driver and then go to C:Program FilesServiceSupportToolinfUSBPAdp it says a better driver could not be found than the one already installed or something like that..
        Starion..
        Do you work for Canon or a dealer in Vic?
        I work for a Canon dealer in Qld and follow the Nethawk install procedure in the above post.Also...remember to use the SAME usb port every time you use the nethawk driver.
        And one last thing...Canon Inc stated this week that they no longer supply the Nethawk cables and that "if you need one you should try Ebay"
        If you work for Canon take the laptop to Canon HQ and have Tech support load it up for you.
        • Starion
          Tech
          • 58
          nah just a dealer.. yeah i've been using it in the same port every time. Will give it another go next week.. As i said, it worked perfectly on windows ME but cant get it to work on xp :S
