canon IR2020 ADD Tonner message, even when the new tonner is installed.
  • Ronald70
    • Jul 2025
    I have canon IR2020, is giving a message ADD TONNER even when new cartrige has been installed - I don't know where the tonner sensor is, any one with the diagram of the canon IR 2020 developing unit or any solution to this problem.
  • montana
    • Aug 2008
    • 392
    Re: canon IR2020 ADD Tonner message, even when the new tonner is installed.
    hi...i believe there is no sensor to be found...but there is toner density adjustment on the HV board....
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      maybe you not using the original toner trying type original as KATUN ..and making the cartridge in her truth position ...it have any sonsor ....
      BEST TECHNICIAN . NICE PEOPLE .
      • Ronald70
        Thanx Montana, I have tried to adjust, but the machine keep on idling and there after (ADD TONNER) message apprears.
        • Ronald70
          Hi Zaza, Thank you for your help, I tried using riginal tonner - blown the tonner tank and add original tonner afresh but ADD TONNER comes on!
