Can't access IPR C1 printer status/settings
  • Hayk
    • 14
    [Dead] Can't access IPR C1 printer status/settings
    Hello. I have a problem with Canon Imagepress C1. Fiery Q1 server is working fine. When I try to print for example test page job status becomes waiting and is not changing endless. I have checked every cable. I don't know what to do, please give me some advice. Thank you.
  • Alex ahir
    • May 2012
    • 125
    Re: Can't access IPR C1 printer status/settings
    printing from pc??
    • Hayk
      • 14
      Yes, of course!
      • Alex ahir
        • May 2012
        • 125
        Ok try printing from copier. go printer/status/function/test page and config page.
        • Hayk
          • 14
          The problem is that i cant access printer status, then function. It says wait a moment......., and never changes
          • irtek
            • Jun 2009
            • 110
            Make sure you are using the Fiery print driver and not the driver for the internal print controller.
            • Hayk
              • 14
              Ok, thank you I'll reply with new information
              • Alex ahir
                • May 2012
                • 125
                That is the problem your fieryQ1 never boot up.
                go to service mode and check the image cont. make it 3 there.
                • bassam
                  • Apr 2013
                  • 7
                  I also have the same problem as possible know the solution and how the information prepared and I do not have the CD to reboot?
                  • Hayk
                    • 14
                    I Checked the image cont. It was 3, so I made it 0, restarted printer, then again made it 3. No changes
