CANON IRC ADVANCE C5045
  • THUK
    • Jul 2008
    • 195
    #16
    Re: CANON IRC ADVANCE C5045
    Hi is it genuine Canon toner and if you do a Bk,Cyan,Mag single colour copies is it the same and i had to wipe all software to clear background issues before.
    I hope this helps.
    • lagustacat
      • Oct 2010
      • 51
      #17
      I hope this helps.
      This is a brand new copier with only 2000 pages, all toners are oem, drums have 2000 pages ,dev units 2000 pages, itb unit swapped out with new one still same problem streaking colors, dirty pages, cleaned secondary transfer roller,80 percent better
      • THUK
        • Jul 2008
        • 195
        #18
        Try a DC Con clear but get P Print sheet first or wipe software.
        • vigour
          • Aug 2010
          • 1038
          #19
          A cleaned secondary gives 80 percent improvement
          What would a new secondary do?
          • THUK
            • Jul 2008
            • 195
            #20
            Hi if secondary transfer is getting dirty is must be coming from ITB assy, is the ITB sheet clean after running solid colour A3 sheets.
            • lagustacat
              • Oct 2010
              • 51
              #21
              Yes i even replaced with new ITB belt and cleaner same problem, when i took the ITB Unit that was streakingand put it into different copier works fine
              • btobject
                • Jun 2010
                • 9
                #22
                check the drum units, c or bk
                • spectraindo
                  • May 2008
                  • 313
                  #23
                  Hint : Clean all Dust blocking glass with the Cleaning Tool which is attached at the front door.
                  Press Settings/Registration - adjustment/maintenance - maintenance - Cleaning inside main unit - Start.
                  After finished :
                  Press Settings/Registration - adjustment/maintenance - adjust image quality - auto gradation adjustment - full adjust - Start.
                  Read the User manual if you have difficulties.
                  • lagustacat
                    • Oct 2010
                    • 51
                    #24
                    After finished :
                    These items you have suggested have already been done before new belt and itb belt and cleaning unit was replaced, thanks for the info
                    • Alex ahir
                      • May 2012
                      • 125
                      #25
                      Hey you got that test page no.10? last time asked
                      • lagustacat
                        • Oct 2010
                        • 51
                        #26
                        Hi Alex i have ordered secondary outer transfer roller, i cleaned original one and the quality is better by 80 percent will do test copy 10 and let you know, thanks
                        • herlin
                          • Jan 2011
                          • 33
                          #27
                          Howcome the lines are not on the leading and trailing edge? They seem perfectly white. It could also be because of the scanner you used to scan the examples. The colored lines (magenta and other colors) seems to be related to the drum-developing units. I would go for a swap of drum-developing units with the ones from other good working machine to elimintae causes. You could also make Testpage 6 on A3 or other large format printed from the Manual Feed ass'y and open the door when the sheet is pulled into the machine. Is the trouble allready visible on the IT-belt when opening the machine?
                          • redzventures
                            Service Tech
                            • May 2009
                            • 45
                            #28
                            Have you tried the cleaning and coating of secondary transfer roller procedure yet? Also, as mentioned above, what is the background image and text? Is it in the original image? If the image is repeating to such a great extent it would be ITB related but you've replaced that already. We would really need to see the original image to know how it differs exactly.
                            However, first try cleaning optics and clean/coat secondary transfer roller.
                            • lagustacat
                              • Oct 2010
                              • 51
                              #29
                              Removed and replaced secondary outer transfer roller problem is fixed, copy and print quality back to normal
