Canon iR1022/1024
  • Tze Chian
    • Feb 2013
    • 36
    [CQ] Canon iR1022/1024
    Hi, i got a iR1022 & 1024 machine, i having a problem of this machine. It will show
    TONER LOW REPLACE NEW TONER
    But the toner still have 40 ~ 50 percent remain. Is it the developing unit faulty? Is it can service or MUST replace new developing unit?
  • northernlife
    • Sep 2011
    • 847
    Re: Canon iR1022/1024
    Take out the cartridge and let it run out till it will no longer do copies. Someone changed the toner before the machine actually stopped and requested it. See this all the time.
    • Tze Chian
      • Feb 2013
      • 36
      That mean i need change an empty cartridge let it run till end just replace a new cartridge?
      If i take out all the toner inside the developing unit and clean it. And then put back the cartridge. Will it work also?
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        This may help you:
        http://www.copytechnet.com/forums/ca...nge-toner.html
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • Tze Chian
          • Feb 2013
          • 36
          fren~ the link u share. PAGE NOT FOUND.
          • Canon.Tech
            • Mar 2009
            • 335
            Can this model scan via USB? I have downloaded the Scan tool box from canon but it says "no scanner detected" The machine prints fine over usb, but there doesn't seem to be a scanner driver for this model!? Customer doesn't have a network so can't use LAN.
