i have canon c3320 , using the bypass tray paper 100 #text, or 80 lb cover coated paper
100lb text set heavy 1 , 80lb cover set heavey 2
all this coated paper set glossy ,100lb text and 80lb cover, paper output , i could see at the end of paper about 3/4 inch ,paper deform, like wave , not flat , if print two side , there will get trouble at fuser output ,,fuser are new ,what is the reason for this , need help ?
