IR 7105. E0069 0000 05
  • aleano
    • Jun 2011
    • 12
    [Error Code] IR 7105. E0069 0000 05
    Any help on this error code, i cannot locate it in the service manual
  • micann143
    • 25
    Re: IR 7105. E0069 0000 05
    error code E0069-05 that problem is from pre-transfer corona have a leakage get a high voltage
    • THUK
      • Jul 2008
      • 195
      hi is it the transfer wire cleaner at the front, it should be towards middle when you fit it.
      • spectraindo
        • May 2008
        • 313
        E0069 initially means leakage in the Transfer charging assy, but often is the Fixing Roller Bias leaking to ground.
        Check the Fixing Roller Bushings and Collar, the Fixing Roller must not contact the body.
        • jiongpao
          • May 2009
          • 414
          E069.pdf
          You may have a browse on it
          • micann143
            • 25
            hello..! yes you can check the both sides bushing maybe it is already broken or there have some gear broke also.!that is why the cause of error e069.
