Canon Ir2200, Fax issue, no "Manual Recieve" mode ??
  • maddawg
    • Aug 2025
    got a Ir2200 with fax option and customer is trying to use it on a single phone line. It appears that there is no way to set for "Manual Recieve"...... any suggestions ??
    • 23009
    Re: Canon Ir2200, Fax issue, no "Manual Recieve" mode ??
    I looked through the Facsimile Guide, and don't see a Manual Reception option. Only Memory Lock, and Transfer.
    How about setting the number of rings to answer at 4 or 5? =^..^=
    • vigour
      • Aug 2010
      • 1038
      http://www.copytechnet.com/forums/ca...-ir3030-2.html
      • maddawg
        don't see any place to increse number of rings but this machine did have this option before the HDD was changed and system software was installed. can't imagine why it is not there??
        • teckat
          • 16083
          The AutoRX/ManualRX selection is accessable from the 'Received Job Status' folder after setting a soft switch in service mode, use the following procedure to access this function:
          1. Enter service mode then select:
          Fax/NCU/SpecialB/SW27, highlight SW27 then bit 7 to change it's value from 0 to 1 then press OK
          Exit service mode. (This will make the autorx/manualrx selection available in user settings).
          2.
          On the lower right of the machine display select 'System Monitor'.
          3.
          Then select the 'Fax' icon at the bottom center of the display.
          4.
          Select 'Received Job Status folder at the top center of the screen.
          5.
          Select either 'Manual RX, or Auto RX' at the right of the display and press 'DONE' at the bottom right for the setting to take effect.
          Note: If you set the unit for manual receive mode you will see a message at the bottom left of the display telling you the unit is in manual receive mode.
