Canon ir2018i - Reservation Mode
  • kuby
    • Oct 2007
    • 1408
    Had a customer call and says their copier is stuck in "Reservation Mode". Turn it off/on and it will print about 5 pages and then go into "Reservation Mode" again.
  • montana
    • Aug 2008
    • 392
    Re: Canon ir2018i - Reservation Mode
    hi..i suggest you to.clear the all memory in service mode....i hope it is help
    • teckat
      • 16083
      Try >>>>>>
      Performing a D-RAM Test in service mode may resolve this issue.
      To perform the D-RAM Test, follow the steps below.
      1)Enter service mode
      2)Scroll to "TEST MODE", hit the "OK" button. The display will show "TEST MODE [1] - [9]".
      3)Hit the "1" key. The display will show "DRAM [1] - [2]".
      4)Hit the "1" key again. This display will show "DRAM TEST xxxxxKB" and the DRAM test will begin.
      *After the test, the display will say "Complete (no error)".
      5)After the first DRAM Test completes, hit the "Stop" key, the screen will go back to "DRAM TEST [1] - [2]".
      6)This time hit the "2" key and the 2nd DRAM Test will be performed.
      If an error is shown for either test, the memory may need to be replaced.
