Calibration C1
  • mido
    • Nov 2011
    • 177
    Calibration C1
    Hi all,
    Pls I want your help about calibration fiery C1 by KOdak color separation, q13
    thanks in advance
  • teckat
    • 16083
    Re: Calibration C1
    Originally posted by mido
    Hi all,
    thanks in advance
    U mean a Fiery imagePass C1
    it's under to Printer Tab on control panel> follow prompts
    Scroll to Choose Calibrate-
    When prompted, select Yes to print the measurement page. This page is comprised of swatches of color that will be measured by the copier and then compared to the target color values. After the page is printed, the Measure Page screen is displayed.
    - When prompted on the Control Panel, place the Kodak Gray Scale strip face down along the top of the copier glass.
    -Place the color measurement page face down over the grayscale strip. Align the top-left corners of the grayscale strip and the color measurement page with the arrow at the top-left corner of the copier glass. Make sure the patches on the grayscale strip do not overlap the color patches. -Close the copier lid, being careful not to move the grayscale strip and color measurement page.
    -Click OK. Status messages display the progress of scanning and calculating measurements.
    -When prompted to Print Comparison Page, select Yes. This page provides you with a preview of the selected calibration.
    -When prompted to overwrite calibration, select Yes.
    -Select Yes to confirm.
    Status messages display progress information. The new calibration becomes the resident calibration.
    -When calibration is complete, choose Exit Calibration.
    if u use Command Work Station see link=
    http://www.copytechnet.com/forums/canon/49292-efi-color-calibration_colorwise-command-workstation.html
    • mido
      • Nov 2011
      • 177
      Re: Calibration C1
      Hi,
      there are two of kodak scale,
      one is Kodak gray scal and the other is kodak color control patches.
      which one of them or two will use for calibration.
      thnx
      • teckat
        • 16083
        Re: Calibration C1
        Hi,
        thnx
        Kodak gray scale
