error 0051-0000
  • anand8620
    • Jul 2012
    • 34
    [Error Code] error 0051-0000
    Hi All
    I am getting Error 0051-0000 in my Cannon IR3300. Please help me to overcome this problem.
    With Regards
    ANAND
  • teckat
    • 16092
    Re: error 0051-0000
    Originally posted by anand8620
    Hi All
    With Regards
    ANAND
    Inspect the contact pins in at intermediate connector J3040-2.
    This is the signal line for M3, the horizontal registration motor./ see if bent or damaged ??
    Inspect area for jammed/stuck paper
    code refers to a problem with the Horizontal Home Position Sensor, or the Horizontal Registration Motor M3.
    The gear and motor are illustrated below:
    • jiongpao
      • May 2009
      • 413
      Re: error 0051-0000
      its usually the small gear broken that attached on registration motor. If you see it closely theres a crack on following gear but it doesnt sell with only gear, so you must get Horizontal Registration Motor
